Dash Lights
For those of you with imports , on the dash left and right of the steering wheel there are two sets of lights , on the right there is overdrive and power etc , but on the left there is a set of lights which have never lit up since I have had the car, anybody know what they are ??:confused:
This is the self destruct light. If you see this light come on, you have 5 seconds to get out before it self destructs ;).
Stuart
Cruise control. I hardly ever use it coz you can't go for more than 50 yards on any of the motorways around here without slamming on the anchors (M4,M40,M25)
So if it's only for the cruise control (which i have never used ) there will be no problem in covering it up , the SBC-ID fits just perfect there :D
Stuart I take it if i just remove the bulbs then i will not have the self destruct problem :confused: ;) :D
I think the HICAS warning light and LIGHTS warning lights are in the left bit, too.. And the ABS warning light.. I think, from memory, anyway..
Oh yeah, I forgot about the HICAS light, but I've never seen the others in two years of daily driver ownership. Junk 'em!
[edited because I'm a dumbass and posted the same thing twice.. Lol - cant' even read my own posts!]
Sounds good to me , knowing my luck after covering them up I will have a warning that I will not be able to see and something will go belly up :rolleyes:
  • 9 months later...
do0 you know what the light next to the hand brake light is looks like a exhaust pipe i think
sounds like the cat overheat warning light
If the cat overheat warning light comes on does it mean the cat is nacked or has it just got to hot cheers
Do ya know if the cat is nacked if the light comes on or has it just got to hot cheers
Baggins
Lower right light on the cluster is Hicas, I know I just junked mine, next to it is a gearbox warning light, I think its oil temp, above them is overdrive and cruise control. on the far left of the cluster is ABS warning on bottom and above is the diagnostic light that I can never get to work.
Theres nothing like dragging up an old post ;)
PMSL just read this and thought WTF I did not start this thread then noticed the dates , only a year old :p :rofl:
FYI problem is sorted now :D
