Tip for cleaning sooty SS exhausts...
No not that Sooty :rolleyes: ;)
I normally use Autosol Chrome Cleaner stuff with a drill attachment but it's never really that effective unless you sit there for hours on end.
But today I sprayed some Autocare Alloy Wheel Cleaner - from Tescos :D inside and left for a few minutes while I cleaned other bits. Then a quick rub with a rag and would you know it they are gleaming!! :cool: :D Next to no effort ;) :D
Well chuffed!
Thought I'd share the experience :)
Pete
EDIT: Ignore this lot, I think it's bad to use this stuff :(
well the stuff is mildy acidic. If you use it too much then your stainless steel won't look very shiny after a while.
I used that on my stock wheels, after a wheil the brake dust starts to stain as the surface wax is eaten away by the cleaning solution.
nothing beats elbow grease I'm afraid ....
spray mine (my tailpipes that is) with WD40, then the black deposits can't stick very well, with minimal effort they kinda wipe clean..every 2-3weeks....
cheers Jon..;)
