My latest idea....
Bonnet vents which direct rain to a small container which then drips the water onto the intercoolers which cools the charge air and raises boost.;)
  • Replies 28
  • Views 981
Originally posted by MikeGroves
yes because whens its rainging to really want to go faster.............................
I knew someone would say that ;) :D
Im looking to move light washers so they squirt on the intercoolers.
I can honestly say that I have never use the light washers. Just wetting the lights does not clean them.
Would that help at all?
Stuart
Stuart
Good idea - I thought of that a while ago. Wouldn't be too hard to do surely.:)
Christ LMFFAO bwhahahahahahahahahahaha :D:D:D:D
No but remember I said the water wne tinto a small container, so iot could be used AFTER the rain had gone. Also, more boost can men you get same power by reducing revs and possibly saving fuel ;)
Once again, simple logic is beaten by full facts.:D :D
yeah but that was ****ing funny lol.
this is harldy like youve invented something lol, its already a proven product, water injection into intercooelrs has been around as long as intercooling lol, you just simplify it by adding rain ???? WTF what if your in a place that doesent rain?
lol then of course you could be far more efficient and just use chargecooling for the intercooler?
nothing new here Nelson
:rolleyes: so dont pat yourself on the back to much, your basically trying to reword water injection lol.
of course all your fuel saving woudl go out the window because the copious ammounts of water youd need *which weighs alot* outweighs the gains you make.
so once again your version of logic is just ****ed :D
I'm not claiming to be the automotive version of Trevor Bayliss :D but my idea was not water INTO the intercoolers but ON them, so that they cool the air inside.
OK it was funny. No offence meant ;)
no it was funny lol, youd need sooo much water to keep a constant cooling effect youd need to much water..
chargecooling really is the ticket, in JHB in the hot temps they develop chargecoolers for the cars and they have little catch tanks in the back with Hot ice (dry ice) what ever you want to call it) good for drag racing.
but in this country climate its probably not worth the effort.
Do the headlamp washer bottle conversion to squirt on the IC's , then fill the bottle with slush-puppies :D
It's not such a dumb idea (well OK, it's is quite dumb. LOL;)), but I'd often wondered why some of that nice clean excess rainwater isn't used to top up the windscreen washers ...
Capturing enough to squirt on the intercoolers would be a bit of a challenge though and even water injection systems use a surprising amount of water - plus you'd still have to remember to put the 50% methanol in ! :D
Originally posted by AndyP
.....some of that nice clean excess rainwater isn't used to top up the windscreen washers ...
HUH? Clean? Well, only if you filtered it well. Otherwise rain is full of dust and particles. Thats why it falls innit! Water vapour condensing around dust etc etc. I'm sure the whole works would soon be gummed up with crap.:( :confused:
I know you wud need more water, but my idea was that it wud be free power albeit temporary and weather-permitting;) :D
Originally posted by Paul C
fill the bottle with hush-puppies :D
I know that'll make my IC's very comfortable, but won't it cost a lot, having to go back and buy new shoes all the time? ;) :D
Anyway - yes, spraying water onto the IC's is good - lots of people have been doing it (GT Tuning have had a kit for their FMIC setup on the 5 Turbo for 10 years now)..
Chargecooling is also good - I seem to remember one of the 5 tuners big power cars (i.e. ~300bhp from a 1.5ltr 8v OHV engine) used a chargecooler..
However the other used an IC..
The virtues of each used to be debated endlessly in the 5 club.. There never was a hard and fast answer - as nobody did any back-to-back tests. Maybe I will one day, on a Z, and a rolling road.
Aha - someone just gave me the link to the specs of the chargecooled car - http://www.bbperformancetuning.co.uk/about/cars.asp
Admittedly it has a lot of other work, but..
Both the new Subaru and Mit Evo squirt water on the intercoolers when you press a button in the car
Yup, but I bet they don't use RainWaterTM
Is there a part number? Is precipitation from cumulus clouds better than that of nimbus?:D ;)
how about electronics which turn heat from engine into electricity to cool the water;) :D
Water spray onto the intercooler has known and well documented benefits...but you really need to use a "mist spray" rather than pumping water straight onto it with headlight washers. Lot's of the scooby boys have found they can get the right size droplets from a nozzle from B&Q :D
I'd like to point out that lowering charge temperatures, lowers inlet temperatures and improves efficiency of the engine, but that any actual increase in boost will require a corresponding increase in fuel.
Chargecoolers rock.
Your best bet is a dual speed pump for on / off boost.
OK Whilst we are on the subject on using nature to go faster, why not fit a big lightning conductor on the roof to take advantage of lightning.
1.21 jiggawatts.
Nuff said.
Chargecoolers rock.
But I would have thought a B&Q type of spray would just get blown away before it reaches the intercooler. I mean spraying water on the plants and half the spray hardly reaches the plant, 1 inch away ;)
Stuart
1.21 jiggawatts.
Nuff said.
That is the stupidest thing you have said Senna. 1.21 Jiggawatts. Do you live on this planet? Just get a Mr. Fusion™. :D ;) :p
Stuart
Don't forget to remove all the paint from the body shell too...
(Hello? McFly?)
All De Lorian's didnt have paint. They where made of Aluminium.
Stuart
Nelson, just move to Siberia!
No, please!:D
