Loose rear end
Checked the steering rack and linkages at the rear, all nice and tight and no wear. I think it maybe shockers, as it does`nt like white lines in the road. Any ideas or suggestion? thanks.
Two common things that go on the back.......
The ball joint type gadget that joins the rear track rod ends to the hub
and
The rear shockers as you suggest.
Andy
Thanks andy, the ball joints are ok, so must be shockers.
cheerz.
also, if the tracking is out on the rear wheels it will cause this. get a 4w alignment done too.
