Another stupid O2 sensor question
Hi!
I got code 53 from ECU diagnostic, but the car passed the "flash test" with engine running at 2000rpm for both sides. This give me 2 question:
1) May I take the "flash test" when the car hesitates/judders? (The car was running just fine when I did the test....of course!:) )
2) Can the passenger side O2 sensor be damaged even though the "flash test" was good?
Thanks!
Confused EgilTT
Most onboard diagnostics rely on the ecu recieving a voltage that is of a certain specification.
outside of these figures & it flags a fault up as it must be high resistance or open/short circuit.
so if its only playing up intermittantly it will still regester a fault.
