Code 53 and 21..
Hi!
I ran the ECU diagnostic on my 90m ZXTT and got the code 53 and 21. My car is hesitating and stumbling (the whole car is shaking). The car is worse when it's half warmed up, but it's also a great lose of power when it's warmed up. When the weather is cold the car could be just fine for about 5 minutes, but when the weather is warm the car is a nightmare from the beginning of the ride to the end...could this possible be a damaged PTU...? (and this may give wrong signal to the O2 sensor at the passenger side?)
EgilTT
21 is generally the PTU.
53? cant see that on the list but 43 is the throttle position sensor.
Stuart
the list from TT's of dallas has got code 53 as the right side O2 sensor.
bad luck with the PTU mate, although if you do a search on the sight i think you'll be able to find someone who can get hold of one for a lot cheaper than from nissan.
It's kinda tricky though, I've had less than 100% success with the ones I've done ...
Originally posted by SRRAE
The OZ forum has a write up on how to fix it.
