Should be a big improvement over the standard ones.
The disks and pads are miles bigger than stock.
Dead easy to do - only took half an hour each side.
:eek: What did you do mate ?. Trade in your front bumper for them :D.
Looks good mate. I've just sourced a set myself from the GTR forum (from an R33 GTR)
Should be on for Billling.
How easy was it to swap the calipers out ?.
Any hints and tips ?
Mine are from a R33 GT-R V Spec and were dead easy to fit.
All you do is unscrew the brake hose then unbolt the two 19mm bolts that hold the caliper on.
The old disk slides off and you put the new one on.
You have to bend the dust shield back thats behind the disk but it's only a thin plate and just needs a shove.
Then you bolt the new caliper straight on but you must use the original Skyline bolts. The ones off the Z caliper are a fraction shorter and have the wrong thread.
If you don't get the bolts with the calipers I'm sure you can buy them at a hardware shop or from Nissan for silly money.
