Viscus Fan
Alright Lads,
I have had an engine noise problem (blowing / fan type noise then a screeching at 5K) on my Non Turbo for a while. After being in for an alternator change the garage said the noise could be from the Viscus Fan? Anyone had this problem? Any idea's where I can get one
G
Check it still spins on viscous - with the engine switched off of course - spin by hand to see if it has a jammed bimetallic spring clutch. The load could cause belt slip if it is jammed and you would waste fuel power
cheers ill give it a go
G:D :D
