I've recently put a new steering wheel boss on, which was a pain in the arse to fit. I ended up taking all the old boss/electronics off and re-fitting the plate with the 3 contacts only. I then realised that each electrode controls something different and the contact plate on the end of the boss only contacts with the middle electrode only. I rewired it thinking that they were for the cruise control only, so that the middle electrode was for the horn. The very first sharp corner i came to the HICAS light came on.
Now i need to know how i'm supposed to fit the boss properly, and also which way round the wires went to set them back to normal.
Can i still drive round with this light on or not???
Thanks..........
Stu,It's got nothing to do with the wires,you have not fitted the steering wheel on straight;)
Bugger!! How do i sort that out then? When the wheels are straight, and i'm driving down a straight road, the steering wheel seems in line.
Did the boss you buy have a black plastic disc with a square cut out on the back of it?
sorry didn't read the message correctly. The boss was just straight through. 6 fixing holes on the front and a circular contact plate on the back. But it did have 2 hexagonal locating studs, about 25mm long on the inside of the plate at the back which i couldn't figure out.
Have i been given the wrong one?
When you took off your old steering wheel,you should have been left with a black plastic disk that turns? don't tell me you have taken that off?
That controls the hicas,then the new boss has a plastic disc on the underside that locates into the two tabs.
sh1t! yea i completley dismantled the old boss. But the new one didn't have any plate on with tabs, just the two long metal hex studs. I've phoned up RSM where i bought it from and they said its the only one momo do, and that sparco only do one as well thats basically the same.
oh...thanks for you help Mac. Much appriciated. Where's the best place to get one from?
I got a boss from Smithy,fitted a treat with the Momo Race wheel,with cruise buttons in the centre cap,(on Z i sold to Pete)give him a ring,he may be able to get ya one;)
