pulley play
Is it ok to have play in the power steering pump pulley ( i think its the steering pump, its the one at the top on drivers side).
Its only small amount of wobble , about 1mm but im worried it may damage a seal and pee out fluid .
Anyone have same prob, or know if its ok like this?
Thanks , Trev.
Is your belt tight enough? When i took mine off i think you could wiggle it a bit with no belt on, perhaps a tighten of the belt will pull it into line.
Good luck.
