black smoke
hi every one should i worrty about this
whenthe car is in neutral and you rev the engine i get a little black smoke that comes out just is this the start of bad things i do have a full stainless exhaust on the car
Could be a number of things.
Which isnt that helpfull really.. ;)
However, you should probably get it checked out by a Z guru to see what it Really is.
However, it sounds like it could be the turbo's. Is it one side or both?
Just read my lkast post...
I am in NO WAY a Z guru! :)
'S just that smoking turbo's has been a recent topic for descussion.
Oh and check the thread on
GROUP BUY on PCV and breather parts - smoking turbos? READ THIS!
Might be of some use.
i aslo get a tad of black smoke from mine, even when normal temp, i read on a site about the gurgley things in the wheel arches AIV's??? not sure what there called, but apparently the ecu overfules by 7% so this could be why i get shitty gas mileage and a bit of smoke
hi guys i had a diagnoustic check done this evening and the car is runnig very rich there is a air leak on a valve which is making the car idel at 1250rpm thus causing the black smoke
Andy(El Sol) is that you?
no its not but i do know el sol in ewell my shop is near heathrow
LOL as they say dont believe everything you read on the net :p
Black smoke is fuel defo, can be caused by a few things causing the car to run rich.
but like they say "a car can run rich a million times but only lean once lol"
to rich can also be harmfull.
