protoj ·
sorry i keep posting sub threds but i am still not sure and i know you lads / lasses know your ICE any way
i already have an amp and i have been warned off getting 2 12 inch subs which take 125 WRMS
and been told to get 1 that can take 250 WRMS
i have been told to get a Cerwin Vega HED 12 inch sub at leeds car audio
and i have been told at unicar to get a JL Audio W3 12 inch what you all think they both say each others is better or do you think different ?
thanks
Simon
