Just got the car back and my det sensor has gone. Have any of you had trouble with the resistor solution? Car has done a shade short of 80K miles and although the turbos are reel good for now, I`m thinking about leaving the det sensor as is until I have to get the turbos replaced.
ย
Any thoughts?
if you replace with resistor basically all this does it not put you in safty boost when you are detting
ย
fine if your engine is fine but bad if your engine is bad,
ย
you can have your det sensor relocated but a lot of people seem to think this is not a good solution due to the extra resistance in the wire you are adding
