TT Zed Anti Slip?
My Jap import tt zed has Anti slip as standard....it can be quite anoying..i have found the relay in but it affects hicas so is there any way of disabling the factory anti slip?
You mean the ABS??? Why would you want to disable the ABS??? :confused:
sorry not the anti slip ,abs/ i mean the skid control supposed to stop you wheel spinning under acceloration, when it does work mainly in the wet it just seems to make the engine rev more before any drive is really achieved and can be anoying...
LOL!! you mean your clutch is slipping????!!?? :confused:
Bwahahahahahahahahaha
As far as I know Traction Control was not offered an extra at any point on the Z32.
Are you sure you just don't have crap tyres?
Tim
its even listed on the relay main cover and a relay also is under neath....the system only resets itself when you turn the ignition off then back on after a few moment's.....look at the relay box on the drivers side ....as soon as the wheels try to slip in the rain or dry the system seem's to activate with very noticable affects..
Yep, does it have FL30A written on it too?
and look a bit like this?...
That'll be the ABS fuse - I'd leave alone if I were you!
Tim
That'll be the ABS relay - I'd leave alone if I were you!
Tim
No I think you'll find its actually the FUSE :D:D:D
If you DO want traction control though just do a search on 'Racelogic Traction Control'.
That really does work and it's well worth the money ! ;)
konrad
