Std T25 vs T25 Hybrid?
Hi Guys
On a lightly modded engine i.e. 1 bar boost, exhaust, chip, would there be any advantage of having hybrid T25s over standard ones other than the longevity provided by the 360 thrust bearings (ie. do you need greater mods eg bigger intercoolers, injectors etc to take advantage of the the bigger compressor wheel/housing of the hybrids)?
Jon
Originally posted by JonJon
Hi Guys
Jon
nothing, you get no performance gain from them power wise what so ever, so who ever tells you by adding a 360 thrust bearing gives more power is talking as much shit as the minister of information for IRAQ lol.
they are good for reliablity, but in order to get power you need to have larger exhaust housings, and larger impellors ect.
hybrids should give a power increase - a hybrid is, as its name suggests, a hybrid of 2 turbos, usually a smaller turbine to allow quick spool up, coupled to a larger compressor to give higher air flow.
