Mines an Import and has "apparently" been converter to kmph but its really vague. When I go up the range it seems ok but coming down I can nearly be walking but my speedo says 35. It does this at other speeds to. Bit quirky? And dangerous for the licence
had a cortina that did that once, it had teeth missing from the speedo cable end, maybe that or the cable not fitted properly
Did it stick at various speeds?
Does a Z have a speeo cable? I thought it was something to do with electronic pulses??
yes it did stick at various speeds.
I dont know if zeds have cables as have only had mine a few weeks, but thought would offer the info in case it helped
No the speed it detected from a speed sensor on the gearbox which sends pulses to the speedo.
Stuart
guess that u would have to take the speed converter out first .....
then either sensor in gear box or new clocks .......
then again it could be something simple like a corroded connector on the gear box
