Got a strange problem. when driving along in first gear for instance will run fine up to 3000 revs then not budge above really. sitting with the car in neutral and rev it, it will get up to about 6 ish then start to die. Basically whenever the boost guage would go above the 0 point it won't move.
Also at this point there is a hell of a noise from the front like a boost leak. I've disconnected now the recirc valves so it is off. This is where the noise was coming from but performance is still wrong. ECU says 55. If i disconnect the big pipe going to the recirc valve coming from the air inlet pipe going to the turbo from the afm (If u know which i mean) It will run better and get above 3000 revs but still not as good as it should be. boost goes up to about 2psi. This means that air is entering after the afm and its running better. I'm thinking poss afm faulty but code 55.
I've removed the air filters as these were clogged so these aint the problem
Also when it is running with foot flat to floor and only 3k revs there is a hell of a lot of black smoke coming out of the back as if it thinks there is plenty of air going in so its overfueling.
Can anyone clarify this or any other ideas please.
Another thing poss related is a loud hissing noise on idle from under the drivers side wing. there must be a leak in the cat gubbins but i don't think this is affecting it as i have removed the suction pipe from the plenum and blocked it to eliminate this from the closed loop and it still has the same boost problem.
Please HELP.
