electric super charger fitted
For a laugh i fitted one to my NA
looked like a drain pipe !! hehe
well when i turn it on with normal revs the engine cuts out cry cry
the air flow is going the correct way so what is it?
do i need to be going fast before i turn iot on?
My mate thinks it maight give me a extra 5 bhp and i got it cheap!!
  • Replies 63
  • Views 2.7k
so why did it stop the engine
it i reverse the airflow then the engine stop but slower like its straved of air which is what i thought would happen
So what is it, an old Morphy Richards hairdryer ? Switched to cold I hope ! ;)
Nop not a joke
i thought i would fix one and see what it was like
it is just a high speed motor and fan in a 3" pipe
blows very hard
but cuts the end off!
it is between the airflow meter and the k and n induction kit
Try putting it after the airflow meter...
oo good idea
but then the engine wont no how much air its got?
also wont the suckion cause the same problem?
Originally posted by burf2000
oo good idea
Yeah cause it's sucking the air through the AFM
No, the airflow meter is very sensitive to turbulence - if the fan is directly b4 it then you probably won't get an accurate measurement of the air flowing through it. If the fan is after it - a reasonable distance - then this turbulence won't be a problem....
CheerZ,
Andy
So Why does the engine cut out straight away then, cause the afm has gone off the scale?
I will try and move the supercharger to the other side ?
Strictly speaking people always fit 2 of these and fit them just before each throttle body. Under WOT they will cause a restriction in airflow and massive turbulence. If you fit a boost gauge you wont find any boost pressure in the plenum at all.
Still at least you got it cheap :D
Paul
So you dont think it will do anything then?
Remove it lmao, bet the car runs better :D
and they arrested Hugh Grant for doing this as well!
Apparently it was his foot moving on the brake pedal that gave the game away.
we are talking about the same thing arent we, getting blown?
Get back to the subject please
So non of you know why a air increase should stop the engine?
do you mean its running all the time, ie at idle, or does it just cut in at higher revs?? at what speed does the engine die.
your not trying to switch it on from idle or anything are you??? ie with the throttle shut.
I did try at ide (sorry)
But then i started it up and reved it to about 3000 rpm and then turned it on
I am scared to turn it on when moving case i crash
you would only want it on at WOT i would imagine.
silly question but what is WOT
So you think it will work at 5000 rom +
why would it kill the engine then
