blitz sbc-id settings
Has anybody got the gain settings they have set up with this system which is a starting point to run about 15psi boost and the recomended safety setting and peak settings.and what other scamble setting have u set up at.
thanks Richard
I have mine set at a gain of 10 and the boost set to 45 I think.
Set the limiter to 1bar.
These figures will vary from car to car slightly.
On mine a boost setting of about 35 gave around stock boost, 45 was about 14.5psi and 55 was about 16psi.
The gain setting alters the speed at which the boost builds up so a higher value makes the car spool up much quicker and feel faster away from the line but set it too high and the boost spikes too high and can hit the limiter too often.
Make sure you turn off the auto learn mode as it doesn't work on a twin turbo.
