Rear bumper removal
Does any one have any tips on how to remover the rear bumper? Or has any one seen any tech on how to do it?
Stuart
Just undo all the bolts in the boot there must be 15 of them:(
WHAT?
15?
Is that just for the lower part if it?
Stuart
Hi
just removed mine!!
quite easy more so than the front.
1st remove all trim in the boot area and then you will find about a dozen 10mm nuts this holds on most of the rear bumber, there are 2 each side inside the boot holding up the corners/returns of the bumper,then you will find 1 each side under the wheel arch [outside] area b careful these may be corroded and may sheer under pressure make sure all rear no plates etc are remove/disconected then you will find about ½ dozen olastic nuts/bolts underneath the car, i could not release these so got a small chisel and chopped them off [will use prober ones when i refit!!] and thats it.
Took me about 25 mins "all the best"
cherrs
Dave
:D :D :D
Originally posted by SRRAE
WHAT?
15?
Stuart
No look on the rear panal inside the boot, you need to take off the plastic trim then you will see lots of 10mm bolts;)
I have a load of rust in that area. Including where the tank neck cover nicely collected a nice pile of mud for me while later on just ate the inside of my wheel arch :(
Stuart
