Finally fitted it!
I finally fitted my induction kit at the weekend, a major achievement for someone as Mechanically inept as me :D, 6 months after I bought it!
Anyway, nobody mentioned it was such a barstool of a job removing the front two bolts to remove the stock airbox!
It took me an hour to remove two bolts!
Mike
Yeah that bit is a b&stard! How are your arms? Mine were in tatters :D . Well worth it though ;)
Pete
You found the secret invisible bolts as well then or did you just break it off in the end :D
Found all the bolts ok, half tore the spashguard as i didn't see the bottom screws until later, Doh !
It does seem a bit quicker, but that is probably my imagination.
Mike
Yep those would be the invisible secret splashguard screws LOL.
What zorst are you running with it ?
Standard Zorst :( ATM:D
Hope to be buying a Mongoose soon (ish):confused:
Mike
Mate i go to do this soon
are you on about the 2 large long bolts at the front?
Or is it a new surprise for me
Underneath the front there are two screws connecting the airbox to the splashguard, I only saw them after I half ripped it out!
Mike
