Help
Just finished polishing the car and noticed underneath that a belt was showing. Pulled it out and it is snapped. I havent a clue how long it has been like that but all seems to be ok.
Opened the bonnet and it is the one to the right of the fan and seems to link about 3 cogs (is that the right term?) together.
Could someone please tell me what it is for, would i have done any damage and how much to replace.
Many thanks
Martin
ps if it is any help it has Nissan 11920 - F6501 4pk965 written on it.
[This message has been edited by martinfa (edited 08-07-2001).]
Hi Martin,
Does this help...
It maybe the one that goes around the A/C compressor, Idler pulley and Crankshaft pulley, if it is I'm not sure what the effects would be. frown.gif
Trev.
IT DOES SOUND LIKE AIR CON BELT IF SO
IT JUST MEANS YOUR PUMP WONT BE WORKING AND THEREFORE NO AIR CON,
check that the pump hasnt seized as a precaution if not belts are easily replaced and relatively cheap. if it is the air con belt you are ok to run the car but makr sure it isnt the belt driving the water pump if it is dont run the engine till its replaced
how would i check if the pump has seized?
cheers for the spot on answers guys
martin
To check if the pump has siezed, if I remember right, try turning the inner pulley on the pump.
Or try putting a new belt on it, then watch the pump (the outer pulley should spin all the time) and get a friend or relative to engage the aircon inside the car.
The pump clutch should engage the inner pulley and spin the whole unit.
If it does spin and no cold air is coming out then you could be low (or have a leak) or R12.
This can be replaced with,I think, r69 or something equivelant as r12 is banned by the barmy nutters in Brussels frown.gif
Glen
Yep , It 100% the Compresspr belt for the Aircon , I only know as i changed mine the other week , It's £14.00 (Nissan) so nothing to worry about and it doesn't do any harm driving the car without it, just no aircon .
GEE The R12 is expenissve tho !!!
Cheers DAZ
right, got it
cheers guys, i will have to check the r12. i know this has been discussed already so i will search.
once again ta
over and out
