Just tried to do an ECU diagnostic
I tried to do an ECU diagnostic on my car.
Took the carpet out, removed the footboard and looked at the ECU.
It doesn't have a potentiometer or LED window.
Where those are supposed to be, my ECU just has holes.
WTF?? :confused:
Is the ECU different between UK cars and imports?
Eric , it should be on the left hand side , no LED display just a small bulb that flashes red , alongside this should be the screw ( potentiometer) , not the easiest place to access witha screwdriver.
HTH Phil
Cheers mate,
There didn't seem to be anything in those holes but I'll try and squeeze under the dash and poke around a bit more ;)
mines got no potentiometer either. use vijay's link. :)
Cheers,
I've found the grey plug just above the bonnet release.
Do I short the pins on the left, or right hand side of the plug?
Bit confusing with LHD and RHD ;)
Short (joke intended) answer is don't know !!!! But it doesn't matter becaase if you look at the plug one end has a block of 2 connectors and the other a block of 4 (with the tapered corners). Once you see that you can work out which pins to short.
Andy
Originally posted by Eric Manktelow
Cheers,
Just worked that out :o
I'm such a dork! :)
