stereo wires
just removed my stereo ready to install new sony HU at the weekend
sussed out the wires are these right:
found speaker wires ok
Yellow - permanent live
Blue - live on ignition switch
Green/red - not sure??
Red/black feed elec aerial
Andy
the green/red wire might be the feed to the rear amp.
Vijay
is there any way of checking this
Andy
....And this may help, which I picked it up off of a post on one of the other BBs (Ben's Aus forum) and covers an import:-
Audio Wiring colour codes made easy!
Here are the colour codes
Ground - black
accessories - red
permanent battery - yellow
rear right positive - brown
rear right negative - black/red (2 of these!)
rear left positive - blue
rear left negative - black and white
front right positive - orange
front right negative - black and purple
front left positive - green
front left negative - black and yellow
Antenna - black and red (test these out because there are 2 black/red wires)
the wire in question is green with red stripe
Andy
double post :rolleyes:
I presume someone's cut the wires to install a stereo already, otherwise you'd just be using an ISO adapter? If not, this may help...
I took out my old stereo last weekend and this is part of the sticker that was on the stereo, showing the layout of the wiring in the connectors. No colours though. :(
