help!!! sum of u have helped with my prob of bursting rads,well its all back together now,but not sure if im paranoid or not.THE water pipes feel quite hard after ive been driving it,they r still squeezable,but no where near as much as when its cold,when cold i can touch both sides together -)(- but when hot theres only half an inch or so movement from each side -0- is this normal thanks guys............
firm hoses when good and hot is just right! If they had too much pressure then the rad cap should vent it.
i should fooking hope so laddy,ha ha but seriously ive had loads a probs with bursting pipes n rads,but ive replaced everything,so im outta cash and holding on bye a wing and a prayer,im hoping its not head gasket,shes running so damm fine at the minute....
you can have a pressure test done on the cooling system at any good garage, if you're concerned about it then this might be a good idea.
