inner brake light mod
Has anybody rewired the rear inner brake light up to use them as a fog lamp, mainly a conversion on j spec zed I believe.The reason I ask is that whilst fitting the veilside rear apron I can't be arsed to french in the uk fog lamps .I thought of using a diode inbetween each set of light bulbs on rear clusters and then route the foglight feed to the inner brakelight, so when fogs are on only inner lights work and brake lights work seperately. but when no fogs on both sets of brake lights work. If you catch my drift, or use a series of relays to do the job.
whats the best way chaps??? :confused:
yours one busy zed owner with it in more bits than I care to say
sob.....sob..
