No Lights
changed the centre consol around the stereo today and put in new front speakers, went to put the lights on and when i turn the lights on i only have high beam on all the time , no dipped beam, front spots, rear lights or dashboard lights.
Checked the fuses by the acc pedal and all are fine.
Any ideas much appreciated
Check fuses under the bonnet in the black odd shaped relay and fuse box on the passenger side wing has the fuses for the dip beams marked so should be able to locate which ones, when these blow the relays default to high beam only so likely fuse problems here.
Jeff TT
Cheers Jeff turned out to be the clear illumination light fuse in the drivers side foot well, replaced the fuse and hey presto all is fine .
Thought the fuses were ok but then i suppose it did not help looking at it in near darkness last night , much better this morning in light:D
