Clutch Booster
My clutch booster is defintely f**ked.
Anyone help, ive looked at the manual and cant work it out......
Do i need a new one? i suspect so...
Dan
JAP '91 2+2 TT
LOL!!!
are you asking or telling??? if the servo is deffo f**cked as you say, then of course it needs replacing!! :D
just make sure youve checked the vacuum lines.
Problem is i know its f**ked as it doesnt work and makes a strange noise...
Unfortunately i cant locate it!!
I assume it was to the right hand side of the ABS unit in the Engine bay but there is nothing there expect a resevoir for fluid (i checked this and it was ok.......
Im very confused.........
I think it is inside the car.
Must be real pain to replace.
Have fun:D
You should find it bolted to the rear of the clutch pedal box - engine side of the firewall (afaik). They're pretty expensive ($300+ from Courtesy).
If you can get your hands on a master cylinder from an NA you can take the booster and hoses out (blank off the vacuum feed) - you will find the clutch pedal a bit stiffer though due to the stronger TT clutch s'pose the NA master cylinder would have a hard life too....
Cheers!
RobH
