Erratic Idle seems to be over
After my post about my car behaing badly at idle and sometimes when cold shutting down I decided last Sunday to try few of what u guys told me and so far everything seems to be ok.
The only think I did is to remove the Air Idle Regulator (Dont know if this is how its called) that closes after five minutes.
I opened it and cleaned using WD-40. I also use WD-40 for all the connectors.
Then I also discovered that one of the engine vacuums was disconnected (this causes erratic idle i know for sure). After putting it back I start the car and so far is working fine.
Tip: I aslo cleaned my engine with WD-40. You wont believe how clean it gets. I used it every where and then I wiped it off with a cloth. It looks like new..Honestly, you wont believe in your eyes.
No posts to show
