Lumpy Vibrating engine
2 pm today driving back from work car seemed to start to judder. Was worse at lower speeds.
Also the power seemed to be dramatically reduced.
When at 60 mph you could still feel a vibration coming from the engine as if it was trying to push the car back as I drove.
Is this one of the coils/Plugs or something more sinister.
Had ordered plugs from courtesy on the 21st of Feb. which havent arrived yet. How long does it usually take to get stuff form the states??
Will a ECU diagnostic shed light on this. How do i check the coil packs are OK??
Roy
That sounds like a mis fire.
Check all the coils and make sure all the plugs into them are in corretly.
Stuart
Yip
That was it Running on 5 cylinders one of the connectors was after popping off.
Its unusual to have a problem fixed so fast and for so liitle money
Thanks stuart
