engine internals
so while refreshing my engine found out its actually got two bent rods 🙃 looking for rods and pistons for a TT stock or aftermarket :) let me know what you got :D
34 minutes ago, JaiKai said:
Set of Pistons Purchased in 2020, fitted to my current build and barely run in,
Upgraded to a size bigger so these have sat on the shelf since doing nothing since.
The rods are stock out of a 1996 TT.
Not sure what these are worth so PM me an offer.
Ohh are they std or oversized? Forum isn't letting me DM 😭
2 hours ago, JaiKai said:
Standard size i believe is 87mm which these are, the product code and size is stamped on them 6549M87
They are $217 each from Wiseco
https://www.wiseco.com/shop/auto/professional-nissan-vg30dett-piston-87-00-mm-bore/
Sounds good :) how do I contact you? Unfortunately the forum just says unsupported when I try to message 🙃
