Blue/Purple smoke?!!! Help Please!
When I start my car in the morning sometimes, I see a puff of black/blue smoke. Its only when the car just starts to run and I stop the key. Its only 1 puff and then every thing is fine. No more smoke at all, even when I boot it. The car runs great.
What could it be.
Are my turbo seals going and I am getting some oil in the exhaust.
Help please anyone
Stuart (Slightly worried)
Please get in touch and I will have your car checked over Free of charge.
CheerZ
Johnny
Tel:01942-671239
Thanks Johnny. I shall phone you tomorrow or on Saturday if that is OK. At work at the moment.
Stuart
awwww, now isn't Johnny a damn nice chap !
*salutes*
Hey Stuart - what ever you do DON'T let Johnny drive your car smile.gif You'll end up with more fines than Jeffrey Archer smile.gif LOL
CheerZ,
Andy
Mine does the same, a friend in the states who loves hiz Z gave me this explanation (nothing to worry about:-
The puff of black smoke is just an indication of a rich burn. That's
OK, since when the car is first started, the oxygen sensors run in a loop
function that just sends a preset voltage to the ECU, and they do not make
any adjustments based on the air/fuel ratio. This is because any real-time
reading they would put out would be erroneous, since the catalytic
converters haven't lit off yet (they have to get up to temperature, around
900 deg F, before they work). Once the cats are up to temp and working the
O2 sensors will start feeding realtime data back to the ECU so that it can
make the necessary corrections in fuel delivery to maintain stoichiometric
air/fuel ratios. By design, the initial signal from the O2 sensor richens
the fuel mixture to protect the engine until it's warmed up, so that black
puff of smoke is just an indication of this initial rich burn. No problem.
By the way, the presence of blue smoke indicates burning oil, which could be
anything from rings, to leaking head gaskets, to turbo seal failure. White
smoke indicates water vapor (no biggie), or burning coolant (bad).
Stoichiometric? I can only just say that! LOL!
Tim
As it's blue smoke and not just black, it's worth having a look at. If the seals are going, it doesn't mean it will go tomorrow, it could last years. My seals always had a little bit of oil around them (on the outside!!!), for the past 5 years... so far so good.
