Fitting fuel pump....DIY?
I'm being lazy by not finding out I know...........just thought someone could tell me?? Looking it up on manual as you read this..........
Thanks,
Very DIY,
on a 2+2 its under the sparewheel, fuel lines can be hard to get off otherwise very easy.
Yep not a bad job but fuel lines can be a BITCH!!! Best way if they're stuck is to get some pliers (with a rag to protect the line) and twist the line on the pipe. This will release it then it should come off easy.
CheerZ,
Andy
Turn off the ignition and put out your fag first ;)
