Wipers and Washer issues
Hello everyone... It has been years!!! Hope everyone is doing well
I come on here for some advice, I have recently got my car back after a while as it was rotten... Like really rotten. Everything is sorted now but I have some issues...
My wipers work except for the intermittent wiper option. They will wipe once and then nothing, doesnt matter how often I set them to, they will not wipe again until I take them off this setting - I have had a look at the timing control thing near the drivers side fuse box and the green relay there. All looks good, no bad solder etc. I have changed the blue ACC relay at the back of the fuse box, still not working
The washers are not working either, push the button and the motor does not work, the wipers dont move with it either and the low fluid light is not coming on at all
Any help would be most appreciated
Hi Joel - and welcome back!
This is the main relay - they are NLA from Nissan so it might be worth buying another to swap, just to confirm whether it's the problem.
NISSAN 300ZX Z32 TWIN TURBO VG30DETT WINDSCREEN WIPER RELAY MODULE | eBay UK
Failing that, it could be the switch itself; you may need to replace the LH control pod.
Richard
