Reverse switch problem
Me again.
So I have two questions:
  1. Is this possible without dropping the gearbox?
  2. I wanted to test it was definitely the switch before I went crazy getting it out, so unplugged the old one and plugged the new one in, put car in reverse and switched on ignition and then pressed the end of the switch in but it still didn’t turn the lights on. Does the switch work this way? That you can push the plunger end in and it should turn on?
Edited by RobHowl
#1. 1993 Twin Turbo Manual LWB in black (2022 - 2024)
#2. 1991 Twin Turbo Manual LWB in white (UK) 2025 -
Have you got the right one? The neutral switch and reverse switch are close together and look similar.
