how quickly does.....??
hi folks,
no, not a speed question. Just had entire cooling system overhauled - piece of mind etc.. AND have noticed the following, which is a little worrying.
before overhaul, took AGES for warm air through vents and needle to even move, let alone reach 'normal' operating temp.
NOW it is a halfway (normal) with semi warm air after approx 2 miles/5mins of 'easy' driving - i.e poodling up the road with the usual plumes of condensation out of arse end.
is this normal for all your zeds, or has the garage forgotton to connect anything - needle doesn't move any further and all levels havn't depleated once normal temp reached.
so. is something shagged now, or has it just been fixed and this is normal.
fanx.....
Vicky x x
Sounds about right for mine, :D
Mike
Mines same,,all normal,they do get to operating temp quit quickly if all ok,within 5 mins my needle just a tad below half way,;) Tony
phew:D
thanks folks for swift reply, and thanks for putting mind at rest, is really must of been shagged prior to service then - worth the £120 to sort.
off to annoy scoobies now:D :D :D
vicky x x
