Leaking Targa.
On the Z I'm hoping to purchase end of this month, the bloke thinks the roof is leaking but my mate who's a mechanic & did some work on it recons it's the window not seating properly 'cause of some broken plastic thing in the door which he's gonna fix. Can the leaking Targa be a big problem to sort out if it is this? Cheers.
Most targas leak. The rubber shrinks and doesnt seal correctly.
Mine leak and the seals that I am gonna try changing next are $200 from the US
I'm almost certain my leak is down to the window, it sits about 2-3mm down further than the other side when closed and even though it sits on the door seal okay i can just see the water coming in, so possibly yer mate is right, however when you take the targa off there are 2 drains, pour water down then and see in if it comes out under the car.
cheers
smithy :cool:
Or you could just cover it with peanut butter!!!:D
