Technical help appreciated
Hi jimmer.
Thanks for message, I was going to pull the pump/sender but didn't bother as I quickly jumped the pump relay connector to bypass relay and the pump could be heard. So it seems the ground trigger is not getting sent to relay as relay is not clicking when ignition is turned on but relay works when tested. Thinking this must be the case for loss of spark aswell ??????
Thanks for trying to help as I'm completely in the dark with it all ๐Ÿ‘
vbgarage.php?do=getimage&id=405
No posts to show
