after 6 or 7 minutes thought it was a bit weird that heater was still spewing out cold air.. it did this a couple of years ago and it was just the mixer getting it's knickers in a twist, so I adjusteted the climate control, changed fan setting, etc..
After about 10 mins there was a bit of heat, but not very much.. all other gauges (temp, etc) all normal.
stopped car to pick up parcel at a couriers, then started again.
After about 200 yards, I just slowed and turned onto sliproad to dual carraigway, and loads of smoke appeared around me (i.e. it was already doing it, but now I'd stopped it was visible where as before it was behind me (it was dark).
By this time I'm on the dual carraigway, so just take it easy thinking it was a turbo smoking bad, or my exhaust leaking (I had a bit of a leak at the cat, so figured it could just suddenly have got worse).
It took me another 6-10 mins to get home....
then when I stopped car, I realised it was coming from engine.. steam... feckin' loads of it.
Under pressure, and coming from top of engine.. bugger bugger bugger.
the gauge showed it as normal temp, but clearly it wasn't and has burst through the head gasket (?).
so, it's cooling down now in garage.
I suppose if I'm really really lucky I might not have damaged head gasket (might reseal ?? what do you think).. more likely that's gubbed.
However, of course the main thing is why the hell did it happen anyway.
My limited knowledge says it's either the fan or the water pump.
well.. if it was the fan (I switched engine off soon as got home so didn't check it was running) which the clutch has totally buggered up on, then it would get hot quicker, sure.. but it would mean the heater matrix would get hotter quicker too, so would not explain no heat in cockpit. Also, would not explain temp gauge staying normal.
So looks like it must be the water pump. If it wasn't pumping, the water in the heater matrix would stay cool, the water in the engine would get fecking hot, and the water around the temp sensor would be normal....
Thing is:
1) it was replaced by NISSAN (well they TOLD me they replaced it) when cam belt was done 30K ago)
2) it's on a direct drive on one of the accesory belts isn't it ? And they are all fine... even if it had ceased.. you'd expect the belt to break that was driving it wouldn't you ?....
so.. I'm a bit depressed.
Can anyone shed any light on what are the likely causes of this, what damage I've done.. and what I'm best to do next.. and how much it's likely to cost me ?
just after spending all weekend washing/waxing/fettling too... bummer.
buggering sh*te.
on way home from work (15 minute journey).
Thing is:
thanks.
stu
