i'm the owner of Snowflake Customs, a custom car shop that caters to the Z in Athens Greece. I'm currently working on a "lamborghini" style door conversion kit for the Z32... umong other things are parts that i've developed for myown Z.... here's what's available this month...
Snowflake Customs Adjustabl Tension Rods
Precision crafted of 60 Series High Carbon Tool Steel these adjustable tension rods do away with the vague feeling caused by the rubber end-bushings under hard breaking and cornering.
These rods also allow for ajustments to the caster and wheelbase. With the easy 'LEFT-RIGHT thread' design and bulk of the coupler shaft, you can adjust the rods by simply turning the coupler by hand.
The entire rod, lock nuts and coupler shaft are made of the same 60 series steel which offer greater strength when compared to the 4130 alloy commonly used. The rod ends are Aircraft Quality 22mm heavy duty hemispherical bearings and use a custom 2 piece polished stainless steel adapter shaft (different than in the current pics).
The rods come set to the standard OEM length, but an alignment never hurts and I personally recomend it.
All rods are personally inspected by me prior to shipping against any defects in the material or finish. These rods are the absolute highest quality, and lowest priced available. Each set of rods will be acid etched with your own personal serial number. Incase of theft your rods can easly be identifed. the rods will also have a High polish nickel plate finnish.
This price is only available for this group buy (regular price will go back up to $280+shipping after this Group buy is over).
the price for the group buy will $200+shipping.
I will be taking orders until March 10th, 2003. Im ONLY ACCEPTING 20 ORDERS!
if you are going to take part, there will be a $60 nonrefundable deposit due as soon as you know are interested. at that time I will add your name to the list. So only send your $60 if you are 100% sure you will take part. If you're interested, e-mail me @ snowflake_customs@yahoo.com
Turn around time for these rods will be 7 to 10 days. These rods are of the highest quality, you will not find a product nearly as well made or as stong for this, for such a low price.
If you were thinking of getting tension rods NOW is the time to do it. places will not last long, so send me your deposits as soon as you can!
here are some early pics of the tension rods! as it states above, finnish of the finnished product will be much nicer!
Hey guys... im new to this particular forum...
