Headlight problem
Hi guys I'm having a headlight issue with my z32 every time I put the main ram on my full beam comes on straight away an shows up on the dash as well relays are working and the fuses look fine could it be a short in the circuit somewhere
Could be damp getting into the fuse box, in the driver's side footwell.
Moisture gets in due to loose targa drain pipes, which causes electrical gremlins in that fuse/relay box.
The full beam switch works when I pull the stock towards the steering wheel but when I flick on permanently nothings happening but when getting I put main ram on they come on an shows on the dash as well I checked the main beam plugs an the bulbs are getting power but not coming on atall could that still be related to the drivers well fuse box
Your low beam is on when you try to go to permanent high beam I take it ?
First, replace the 10am fuse in footwell.
Top row 3rd from left.
I had a similar problem & sure it was a blown fuse
I have replaced all my fuses in the footwell with glow ones
