Clutch servo hoses
Hi All,
I'm having a bit of trouble locating any clutch servo circuit hoses with good price and availability. There are five of them and they run from the intake manifold balance tube to a couple of vacuum tanks, a 3 way connector and check valve to the clutch booster. Can anyone suggest any reasons not to use standard pipe such as 8mm fuel hose which seems to be of similar construction but is a bit more flexible.
Anyone got any data for the sort of vacuum created in the inlet manifold? If I knew what sort of vacuum the pipe needed to withstand I think I'd be able to source appropriate hose.
At the other end of the clutch circuit I'm short of the flexible hose that connects the slave cylinder and the metal hydraulic line that connects it to the brass block in the clutch hydraulic circuit. Any reason why this can't be made from a length of goodridge hose and a section of copper brake line?? Could the entire length be made from goodridge hose or is it subject to too much heat due to the vicinity of the turbo??
TIA for any help!
RobH
Hmm...
I feel a bit like I'm talking to myself (nothing new) - LOL
Anyway, I've had second thoughts as the clutch hydraulic lines are under quite a high pressure (higher than brakes allegedly - I've been told a goodridge hose will 'blow off' - I'm not convinced but don't want to take any chances). Fortunately the flexible hose is available from UK stock so no wait :-) I can get the metal clutch line made up from standard brake pipe.
Any comments about the servo vacuum pipes would still be welcome though...
Cheers!!
