Cold weather fuel consumption
Dont usually use the Z when it is bad weather but my last tankfull only made 200 miles before a refill. Calculated 15 mpg!
I guess the cold and short journeys is the problem as it otherwise runs great. I even changed those fuel pipes that leak last weekend.
Anybody getting good consumption right now?
Actually, on a long run you should get better consumption on colder wet days. Cold damp air makes the engine run better.
However, if you are doing shorter jouries its worse. The engine takes longer to warm up and the choke will be on for longer.
Stuart
