Fuse?
Hi guys
Have a z32 import tt 1990 manual swb.
I love it however, My issue is I have no rear lights. I have reverse lights, brake lights and indicators but no rear lights. Could it be fuse or wiring?
Thank you in advance
Ben
Check the fuses down by the drivers footwell, then check the bulbs are not blown. I had two main beam bulbs died on me at the same time once and spend hours tracking around the car trying to work out why. First thing my mechanic did was change the bulbs and they worked fine!
I would then start checking voltages with a multimeter
1 hour ago, phutumsch said:
Don't forget that there is a box, some call it black but I've seen brown ones and it lives on the RH rear light unit, failure could be here.
I second that motion had the same problem. Black box near the yellow cable, should be clipped to the light unit.
2004 BMW Z4 30i
1991 Nissan 300zx TT Project
1997 Jaguar XK8 Scraped ☹️
