Door handle removal key barrel plastic part replaced with metal
When replacing broken part part on end of key barrel, you need to ..
Take door card off
Take two nuts off back of handle
FROM outside you can now carefully pull handle bolts out Which are part of door handle.
At this point you can see both wire rods leave on for now and rotate handle90 degrees or so
You now can get at broken plastic part , take rod out of this one leave the other in place
What looks like a rivet on end of key barrel is in fact a  E CLIP Use small screwdriver and release this
Take broken bit off and clean end of barrel put new metal type on and refit E CLIP
Now refit rod and rotate handle back to original position manoeuvre  back into door
Refit both nuts
And test.
Metal replacement was bought from CZP as a pair they sell new plastic clips also. About £20
Hope this helps
  • 2 years later...
