Automatic gearbox service kit
Hi All
Does anyone have a Part No. for either the filter/sump gasket kit or alternatively the two individual parts ?
My gearbox has started playing up and my first thought is to service it and replace the oil. If it's shot then I'll be going down the conversion route I think.
Many thanks
Hi. Markyb300
If you really want to stay with an auto then get it fully reconditioned  which will cost 2k max.
or change to a manual conversion which may cost 3k
i had 4 autos in 4 years & l have gone manual & everything on the Zed is getting harder to find.
good luck whatever way you go
art
Hi Marky i agree with Arthur,i bought an auto 300zx z32 and despite doing less than 10000 miles in last 5 years am on my 3rd auto box.I have a manual box and bits and bobs to go with it but need to get it on road first before i go down manual route.Or maybe cut my losses and just save up and buy a manual car.
Autos are total pony in my personal experience.
Thanks for the feedback guys. I did a auto to manual on my last 300 but decided on auto this time as I was just looking for a chilled out drive in all situations.
Jimmer I’m having real issues with random idle speeds but I haven’t had a chance with work being a bit insane to have a look at what it might be......the gearbox is sometimes (mostly) fine and changes like it should but other times will hold a gear far too long. Do you think they may be related ?
Maybe it just needs a long run to get everything up to temp etc.
Hi there, it should not need a long drive to get everything up to temp!
Have you done the auto self check on the box? You have not mentioned that.
Art
Hi Arthur
No I haven't ! I didn't know there was one......do you have a link to the procedure ?
That's a very much appreciated heads up.
Hi Jeff,
Yes they have sir. manual gearboxes are scarce over a grand now!
If you can get one. Plus other new parts (fly wheel, clutch plate, slave cylinder ect) & labour
Mind you I did change the coil packs, plugs & oil
Not sure why Im telling you! You know whats involved ?
Art
