Saved one from going to the scrapyard
Hi All
as title says bought one
1989 300zx TT auto
that was destined for scrapyard been parked up for a few years
guy I bought it from started to do some body repairs on it and then just left it
few bits have been removed off it Iam gona try to see if it cranks definitely needs a new fuel pump that’s been ordered and checked all spark plugs there not in a bad state
will try and get it cranked tomorrow and post some pictures up of the car and how I get on with it
will look forward to the advice I get when I get stuck on something
Welcome to the club, great your going to save another Z look forward to the updates.
2004 BMW Z4 30i
1991 Nissan 300zx TT Project
1997 Jaguar XK8 Scraped ☹️
ah an 89 same as mine save that old girl ... ?
Been working on it today
New fuel pump waiting for some ngk prf6b-11c spark plugs
i have spark and fuel car cranks but won’t start going to do a compression test tomorrow
no faults from diagnostics code 55 flashed
Checked fuses and relays so a bit stumped has been parked up for a long time might try and take injectors out check them over as well
Just been looking through the car and I seem to have plugs that have nothing to connect to in the boot I know the aerial has been removed so one plug is for that but i have a couple more connectors
i ll get some pictures tomorrow hopefully
I think it’s too far gone
done a compression test on it today
Results
Cylinder 1 160
cylinder 2 35
cylinder 3 155
cylinder 4 60
cylinder 5 155
cylinder 6 60
I think headgasket on passenger side has gone
thinking rebuild or change
any suggestions
Soft Valves on the 89 Models so it is quite likely they are badly worn.A leak down test would prove this.Unless seriously blown headgaskets do not show on comp tests i am afraid.
