Hi all
Didn't have the equipment to pull the engine out so I'm removing the drivers turbo whilst the engine is in the car.
Everything is off except the manifold heat shield to access the manifold nuts, cant seem to figure out how to remove it. Its loose but it wraps around the front of the manifold and wont squeeze past the turbo intake.
It's a 1993 jap import.
Any help would be appreciated.
you have to remove it with the turbo as you can't get on one of the turbo to manifold bolts till it's out, Or as I understand it at least
You could ask jimmer what u need to do.
also was it your knowledge that the job could be done before you started?
Art
Can get some photos tomorrow if needed.
Read a write up or two and the service manual. Knew it would be a pig of a job but I have the spare time.
Jimmer, have you done it without taking the manifold out then? Or what do I need to do hah
Think i have another plan of attack next time I go at it.
Yes turbos can be removed without removing the manifold, done it many times.
Have photo`s but cannot post them, will see if I link them from an elsewhere.
Sorry for the slow reply, busy few days at work.
Unfortunately the photos just come up with a 404 error for me.
Would it now just be a case of bending the locking tabs out the way and unbolting the turbo?
Bum not sure why the error on the pics, they do show the fixings access and tabs, if you have an e mail I can send then to you.
Jeff
Jeff
Do you have them in an open folder or changed permissions on them Jeff, to allow viewing?
Many sites show 404 error (not found) rather than authentication error, to dissuade further attempts to access.
On 13/11/2020 at 06:43, Wothers11 said:
Thank you, this is much appreciated
Email is
Wotherspoon111@gmail.com
Sorry just seen this, have sent them now.
Jeff
The turbo is out..... not a fun job but worth it.
bolt found in the remains of the compressor fan.
