Rear inner sill
Hi I've started to  to cut the the rust  out of the rear sill the inner sill as all rusted away at the bottom  but I can't see how the bottom of the inner sill is welded  I've looked at various pictures but still  can't see  thanks
Thanks Andrew it looks  like the inner sill  not welded at the bottom  I can't get my head around it
Today I  cut out the rust on the front  sill the centre sill is spot weld to the outer sill along the bottom in the pdf Andrew  post up says it's  not welded is it only welded from  new thanks
