POWER WINDOW AMPLIFIER /RELAY
Hi
A long time ago i out a post up about intermittent window operation and had a reply saying it was probably the Amplifier not contacting properly and there was a picture guide on how to re solder it. i think the reply was from Jeff TT, what i am after is the guide on how to do it.
Does anyone know how i can get it again i have tried to search but no luck !! or if anyone else has had a similar issue and done this, likewise if anyone has a working AMP they no longer need please contact.
Thanks in advance
Simon
I think i just had the same issue as you bud, i found this http://www.twinturbo.net/nissan/300zx/forums/main/view/1126623/Fixing-the-Power-Window-Amplifier--Relay.html
you have to break the case open to release the board from inside though it seems.
The bottom picture is exactly what mine looked like, all i did was heat up that one blob with my soldering iron, move the solder about a bit, then added a tiny bit more solder.
Havent tested it yet but im sure thats done the trick.
